Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 09-11-2012, 12:18 PM
Ajillag Ajillag is offline
Ugh
Is there a hose that go on the back of the egr and where would it come from
Old 09-11-2012, 03:17 PM
oldblu65's Avatar
oldblu65 oldblu65 is offline
Re: Ugh
If you look on the radiator support , there will be a " vacuum line " schematic ( decal ) showing the layout of the vacuum lines and their routing . You should be able to figure it out from that . If not , come back and we'll try to help further - good luck !
" Sometimes I grow so tired "
Old 09-11-2012, 03:22 PM
oldblu65's Avatar
Re: Ugh
What year is your Caprice , what engine , and is it fuel injected or carburetor ?
Old 09-11-2012, 03:26 PM
oldblu65's Avatar
Re: Ugh
See if this helps ?
Old 09-11-2012, 04:06 PM
Re: Ugh
According to that it sating that nothing goes on the back. I know the 2 in front go to the egr valve and the carb. Theres one more. Where is the tps located. It's a 84 305 carb (canadian)
Old 09-11-2012, 07:06 PM
oldblu65's Avatar
Re: Ugh
With a carburetor you normally would not have a TPS but since this was in the era where emission carburetors were being used and electronic engine management was in it's infancy , I can't say for sure that it is true ? I will try to find out but if the carb does have a TPS , it would be mounted to the carb's throttle shaft . I went to Autozone's website and looked up carbs for an '84 305 and nothing was shown in the way of a TPS for that engine ? I would carefully say it doesn't have a TPS but will try to find out for sure .
Old 09-11-2012, 07:27 PM
j cAT j cAT is offline
Re: Ugh
the vac diagram give here is correct. I own a 305cu chevrolet.4barrel carb.
the ported vacuum line goes to the electrical solenoid. the other port goes to the EGR port . the PCM turns on the vac to the EGR when its at the proper engine operation.
if the vac lines are not properlly connected it will run like crap.
also make sure the cannister control vac valve is not broken leaking or disconnected.
Old 09-11-2012, 07:32 PM
Re: Ugh
you ask lot of question. what you try to do ? what you problem vehicle issue exactly ?
give detail of you problem .
Old 09-11-2012, 10:07 PM
Blue Bowtie's Avatar
Registered Offender
Re: Ugh
Ways to tell if you have a Canadian-built 305 SBC:
  1. Instead of 305 cubic inches, a 5.0L works out to more like 411.75 (CD);
  2. The coolant from the heater core passes through hosers ;
  3. You never accelerate, you ”Take off!”
  4. When you use low-octane fuel, it doesn’t go “Knock”, it goes “Knock, eh!”
  5. You open the hood, and the cap on the plastic tank alongside the radiator says “Molson Fluid Only”;
  6. Instead of a wing nut on the air cleaner lid, there are two diagonal pieces of duct tape;
  7. The temperature gauge only goes to -10° C;
The export style 305 in '84 should have a vacuum hose routing more like this:
