Old 09-11-2012, 10:30 AM
moliva1568 moliva1568 is offline
Hub/bearing assembly issues
I'm in the process of changing out the bearing assembly in my 98 cavalier. I'm having difficulty getting the old one out. After a few wacks I thought I made progress but I think i may have made it worse. The assembly came apart and now half of it is stuck inside the knuckle (I think that's the name) now I have nothing to pull on to try and get it out. Any suggestions or info on a tool that might help? I've attached pictures to show what's stuck.
Old 09-11-2012, 12:00 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Hub/bearing assembly issues
Use a hammer and chisel between the hub housing and the knuckle. Work your way around the housing.
Old 09-11-2012, 12:23 PM
that's what i figured. i didn't want to risk damage to the axle though. i'm going to undo the knuckle so i can pull the axle out and have room to get behind.
thanks
Old 09-11-2012, 12:39 PM
vgames33 vgames33 is offline
You can hit the ears of the bearing to try to spin it. I suggest you thread the axle nut onto the axle shaft to prevent damage to the threads in the event of a stray hammer swing. Heating the knuckle and using penetrating oil may also help. You can also use a chisel or screwdriver as a wedge to get between the bearing and knuckle.
If you have access to one, an air hammer makes very quick work of these jobs.
Old 09-11-2012, 12:54 PM
No access to an air hammer unfortunately. I was using a hammer and screwdriver but I haven't made too much progress. I even broke the tip off the screwdriver. I'll have to move to a chisel now.
Old 09-11-2012, 05:41 PM
When all else fails, get a bigger hammer. Its amazing what a pound or two larger can do. Just beat the hell out of it. Any nicks or burrs from the chisel can be filed down.
When you get it apart, run a bit of sandpaper around in there and coat the new assembly in some anti seize. Wheel hubs seem to have a high defect rate, especially with GM products.
Old 09-11-2012, 07:14 PM
oldblu65's Avatar
oldblu65 oldblu65 is offline
If you go to your local Autozone , you can rent the appropriate puller to get the thing off . You just need to move it out far enough to engage the ears of the puller arms behind it . The puller will make a huge difference ! I say that from experience ! You might get it out the previously mentioned way but risk injuring yourself , damaging your vehicle , and " losing your religion " . Really , the puller is the way to go . Good luck !
" Sometimes I grow so tired "
Old 09-14-2012, 03:03 PM
Finally got it off thanks to the big hammer and chisel. Check out two of the bearings
Old 09-15-2012, 09:54 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Wow, congrats on getting that replaced. Looks like it may have been a bit overdue.
-Rod
