Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 09-09-2012, 08:24 PM
dwi1299x2 dwi1299x2 is offline
Question Transmission problem?
Whenever I switch gears and sometimes whenever I accelerate from a stopped position my car makes an ominous *clink clink* noise. Any ideas on what this could be? I'm thinking it may be the torque converter but I am hoping that I am wrong.
Old 09-10-2012, 08:36 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: Transmission problem?
Any idea as to where its coming from? Clicking noises can be bad tie rods, wheel bearings and so on as well. Have you checked your fluid levels?
2003 Dodge SRT-4
Old 09-10-2012, 10:58 PM
All fluid levels are good, not sure where exactly it is coming from but I know it has been making that noise since I bought it back in May. My dad thinks it may be that the CV joints need to be greased. Like I said it only does it when shifting gears and whenever I gun the gas pedal from at a stopped position.
Old 09-11-2012, 08:45 AM
I haven't known the torque converter to make noise when shifting as it only engages while in 3rd gear when traveling over 55+mph or so. Have someone get under the car while you shift thru the gears and see if you can locate the noise.
2003 Dodge SRT-4
Old 02-18-2013, 09:39 PM
XWrench3 XWrench3 is offline
might be a bad engine mount. either broken or loose. i broke ALL of them on a GM car (EXTREME abuse) and the motor jumped around inside the engine compartment like a rabbit on cocaine! once i found out what had happened, i called the junk yard. it was far to late for anything but a burial.
