Old 09-09-2012, 07:09 PM
comet240 comet240 is offline
97 2.2 timing chain and components?
hi i finnally got the oil pan off well not really its hanging i guess u gotta take the exhaust off to get pan off
but i got the timing cover off
and broken parts fell out other then the chain
there looks to be plastic broken off the lower part of this and there is like a metal pin in the plastic side ways
is there a kit to put a new whatever its called in?
is there steps on how to get the chain back on etc
i need a break down or something
this is really a sunfire engine but since no one really replys in sunfire and the cav uses the same engine i hope its all the same
also i need to take off the sprockets i guess is there a pin or something to lock the gears so i can un tighten nuts or whats the trick for that
Old 09-09-2012, 08:54 PM
Re: 97 2.2 timing chain and components?
i found out that the part is the tensioner thats broken
so once i get a new on of those
i also got a timing chain but it says 2004 is that ok do they all use the same chain?
so what are the steps do u need to pull the gears off? do they come off easily?
and how do u line up the gears where you set them?
Old 09-09-2012, 09:42 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Just a suggestion, but you may want to look for a Haynes manual for some guidence. You are gonna want to be sure to get this repair done right or you could create more problems. Parts stores usually sell the manuals, or check the library!
Old 09-10-2012, 06:54 AM
i have a manual i just miss placed it ugh
i guess no one has the hayes for 97 -2004 sunf/cav book that could for now type out what says for lining it up or what not?
i gotta try to order the tensioner now so gives me time to look for book more too
Old 09-10-2012, 07:45 AM
gmtech1's Avatar
^ Tool Required - J 5590 Crankshaft Gear Installer, or equivalent.
Zoom and Print Options
1. Install the crankshaft sprocket using crankshaft gear installer. Make sure that the crankshaft sprocket is seated against the crankshaft.
2. Install the timing chain and install the timing chain tensioner.
3. Compress the timing chain tensioner spring.
4. Insert a cotter pin or a nail into the hole in the tensioner to retain the timing chain tensioner shoe.
5. Install the timing chain tensioner. Do not tighten the timing chain tensioner bolts.
6. Align the crankshaft timing marks with the tab on the timing chain tensioner.
7. Align the camshaft timing mark with the tab on the timing chain tensioner.
8. Install the camshaft sprocket and install the timing chain. Tighten the timing chain tensioner bolts to 24 Nm (18 ft. lbs.). Tighten the camshaft sprocket bolt to 130 Nm (96 ft. lbs.).
9. Remove the cotter pin or nail from the hole in the timing chain tensioner.
10. Install the engine front cover. Tighten the engine front cover bolts to 11 Nm (97 inch lbs.).
Hope this will help!
Old 09-10-2012, 08:01 AM
ya that will help better then what i had, where you get those pics and stuff or you have to be a member?
also i had read you put timing marks at 12:00 position but this works too
ill try that later today if i get the parts
now question i gguess i have to drop engine a bit as there is no way you can get a puller into the gear since the side wall is there
easier if i had a hosit at home LOL
guess i have to get a torch gauge too but helps i guess to tighten and loosen bolts screw driver in the gears
if you line then up like that could they not be off a bit? or is that ok
but ya helps ill have to go down to canadian tire see if they have the tensioner
Old 09-10-2012, 08:09 AM
how tight you tighten the tensioner bolts ad where exactly on the tesnioner when i do get it you put a nail or pin
i going to see where to get a sprocket installer or crank shaft gear installer
and hope a claw puller is good enough
Old 09-10-2012, 09:26 AM
ok so i cant get the part tensioner in till tommorow
but i wanted to know this crank shaft gear installer they couldnt find one
is that just a socket to bang the gear back on or what is it for?
also for getting new seals or is it gasket maker for timing case and oil pan
i not home at moment
Old 09-11-2012, 12:35 PM
ok i stuck need help
1 the engine doesnt drop low enough to get a puller on the cam shaft gear what am i supposed to do? how do u pull it off?
2nd is my 3 claw puller can not get under the crankshaft gear
what puller do i need?
Old 09-11-2012, 12:41 PM
also i trying to turn the cam shaft with a socket but it only turns some and then gets too hard to turn
why is it so hard? is that ok do i keep cranking i wanna line it up
Old 09-11-2012, 12:57 PM
i pulled the spark plugs and i still cant turn the cam shaft let along be able to get the bolt off after
and there is no timing mark for the cam shaft i can see
Old 09-11-2012, 03:38 PM
ok got the gears off finnally and i got the cam shaft gear to turn and poped in the spot for timing had to force it but she went
now i cant get that cup out? do u use a screw in that hole? or something
Old 09-11-2012, 04:20 PM
broke off drill bit inside the oil cup plug put a screw and tried prying on the head but i cant get it out how the hell u get it out
Old 09-11-2012, 08:58 PM
Tech II Tech II is offline
Hope you didn't bend a valve rotating the cam by forcing it, because the crank shaft should have been 90 degrees left or right of timed position(this puts all the pistons at the halfway point).....
You never do a job like this without a manual, and you read it several times BEFORE you start the job....
Old 09-11-2012, 10:15 PM
didnt matter where i put the crank shaft dot i rotated a few didnt postions and still couldnt turn the cam shaft
its lined up now so heres hopeing
