Old 09-07-2012, 07:23 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Distance between sides of engine cradle?
I put my Cavalier in the ditch and bent some stuff up pretty bad. One of the control arms is destroyed (wheel 3" further forward than it should be), and it looks like the engine cradle might be a bit bent. It might just be in my head because the control arm is so bad. Can anyone with a known straight cradle measure the distance between the two sides for me? Preferably at the angled spots on the very front. It's a 2004, and I believe 96 and up are the same.
Thanks,
Jason
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 09-10-2012, 11:45 AM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: Distance between sides of engine cradle?
Measure from the rear near the steering rack side to side and then up front near the lower dog bone and opposing other side from side to side. Numbers should be the same I would think. My j is long gone so I couldnt measure, a new subframe is pretty cheap to buy...
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
The Following User Says Thank You to Classicrocjunkie For This Useful Post:
J-Ri (10-02-2012)
Old 10-02-2012, 09:46 PM
J-Ri's Avatar
Thanks. I thought of that after I posted, It's been a while since I've used my brain. It is bent, but so slightly that it didn't cause a problem.
