Old 09-06-2012, 10:53 PM
thecrow1986 thecrow1986 is offline
2002 gtp electrical issue?
2002 grand prix gtp 260,000 miles but babied, problem is when i start the car everything is all fine but as soon as i turn on the heater blower it kills the headlights and blower wont work till i reach five but no headlights till i shut off the blower? new blower already and no diff. also when i switch the blower speed back and forth the body controil module clicks. any ideas?
Old 09-06-2012, 11:15 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: 2002 gtp electrical issue?
That's a typical symptom of a flaky ignition switch. You can check the Tips and Maintenance section for a guide.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 09-06-2012, 11:26 PM
so even with the car starting fine and no problems getting the key in and out?
Old 09-06-2012, 11:48 PM
olopezm's Avatar
Yes, I would even dare to bet your tire pressure monitor is not working either.
Oscar.
Old 09-07-2012, 05:31 PM
my car doesnt have tpms lol. heres a rundown of what has happened. lately ive also seen water on passanger side floor after heavy rain. last heater blower burned out. put new one in. problems were there before and after new blower. start car and drive it everything is fine, once u turn on the heater knob the drivers information center goes out and the headlights go out. blower will only come on at speed 5 and then the headlights and information center come back on.
Old 09-07-2012, 07:25 PM
olopezm's Avatar
I don't have a DIC, but had the same symptom with the headlights and blower motor when the ignition switch started to fail. I didn't know about it back then and kept driving the car; it took a long time until the starter started to have some lag between the moment I turned the key and the moment it actually engaged, it got worse that sometimes it would be 2 seconds between each event. Everything else was normal and had no other problems during start.
Oscar.
Old 09-08-2012, 10:55 AM
danielsatur danielsatur is offline
Start with the cheapest Test 1st.
1) Make sure your battery terminals are clean & tight.
2) Have both the alternator + battery load tested at the local auto parts store.
There's a lot of demand for electrical power on todays autos, a marginal battery can cause a flaky
BCM problem.
There should be plenty of spare BCM's in the local bone yard.
The Blower Control module is connected to a BAT fuse, it's on a unswitched circuit.
Old 09-09-2012, 07:32 PM
olopezm's Avatar
If you search the forum for ignition switch, you'll find that the lights from the DIC not working are also a symptom of a failing ignition switch.
Oscar.
Old 09-10-2012, 01:32 PM
rkvons's Avatar
rkvons rkvons is offline
Water on you passenger side floor indicates that a deflector has fallen down under your windshield wipers on the right side. You have to kind of remove the plastic cover at the base of your windshield and peak under it. If you can see the blower there, your deflector has fallen down and needs to be put back. Better re-glue it.
Old 09-10-2012, 01:56 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Oscar.
Agreed!
Old 09-11-2012, 10:26 PM
fixed the leak. now the electrical problems keep getting better, now when i turn on the heated seat a buzzing sound comes from the seat. still ignition switch?
Old 09-12-2012, 09:30 AM
Tech II Tech II is offline
See if the heated seat module is doing the buzzing......with the water leak you had, there may be corroded grounds under the carpetting....
Old 09-14-2012, 07:26 PM
i fixed the water guard flap by the windsheild, so the leak is gone i also pulled out the blower resistor and it looked awful. it was rusted solid from the water pouring on it. i changed the risistor and it works here and there but basically the same as before. where are thos grounds? and yea the buzzing comes from the heated seat resistor.i also tried grounding the battery to see if the battery had a bad ground but no change.
Old 09-14-2012, 08:21 PM
Is the module buzzing or the seat grid, two different things(module located under the seat).......did you ever lift the carpetting on the passenger side and feel underneath? If soaked, there might be grounds underneath there that are corroded.....if soaked the carpet should be removed......you will have bacterial growth/mold that will create a smell...
Need a schematic/manual to locate the ground for the heated seat system.....
Old 09-14-2012, 11:01 PM
its def the module under the seat. as far as the carpet there no smell. i have a auto steam cleaner and i removed the water right away and spayed it with antibacterial spray for mold
