Old 06-05-2003, 12:15 AM
CRXsk8er CRXsk8er is offline
Send a message via AIM to CRXsk8er
sub box size......???
can sumbody try and figure out how big im gogin to have to make my box??
the first thing i would want to kno is if the box has to be the size it says or can it be alittle different......???
this is what shape it is goign to be i need to kno how high it has to be... with the shape of it, its hard......when you go to this site
http://www.circuitcity.com/detail.j...ark_0&oid=71445
it says {for a sealed box the volume should be 1.25 cu. feet}
i want to build this box now so the back it done except for lights......but i need to kno how big to make it
i kno this is very confusing how i put it but if you can figure it out it would help a lot......thanks
the measurments in the pic ar ........6 inches........13 inches..........and 33 inches....
Old 06-05-2003, 12:19 AM
i forgot the pic here it is.........
Old 06-05-2003, 12:22 PM
killah_xft killah_xft is offline
Send a message via ICQ to killah_xft Send a message via AIM to killah_xft
well if that bottom piece is 6 inche tall, then the rest should just fit the subs, it'll be easier if you are building the box to make the sub mount piece first, and then make the back panel last.. that flat surface the subs mount on should only be big enough to fit the subs with a little room to spare, but be sure that your subs clear the back or your will have problems putting the back panel on..
Black 1999 Honda Accord LX, Bombz Cold Air Intake, DC Sports Ceramic Exhaust header, "Rally racing" Foglights, 400 watt coustic 401SE AMP, 450 watt Bazooka TVB 141 Tri-vent triangle sub. 220 watt Pioneer 6.5" 3-way (in doors).
To come: Dynamat, Borla exhaust system, and 17" Koenig Absolute (black w/ chome lip), Coilovers, & camber kit (1-1.5 drop), Extensive Engine mods.
check me out on: http://www.cardomain.com/memberpage/515191
Old 06-06-2003, 03:40 AM
also I would suggest looking for sub box designs... each design has a different sound, or quality to it. I would really suggest buyinh a box, because then you know your sub won't blast it apart..
Old 06-06-2003, 04:02 AM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
well, if each sub requires 1.25 cubic feet, then first off, make sure you put a divider in the box to separate the each subs enclosure in your box. Ok, if you are building your box outta 3/4 inch MDF, here is how the demensions of the sub box to make sure each enclosure in the box is 1.25 cubic feet internal volume. 14.5 x 34.5 x 14.875 (for long back) 6.75 (for short peice). This should make the internal voulme for each chamber 2158 cubic inches. it's,like 2 cubic inchs less than 2160 (2160= 1.25 cubic feet). Sorry its not exact, it's been a long time since I did this, so sorry I am a little off, but its a start. The basic formula for angled enclosures is higth (-1.5 for wall thickness) x width (-1.5 for wall thickness) x (top ( -.75 for thickness)+bottom (-.75 for thickness)/2)= internal volume (in cubic inches). Since 2160 cubic inches= 1.25 cubic feet, the space you need for each sub, you need 2.5 cubic feet total (1.25 per sub chamber). That should be the math, so you should be able to figure it out from there.
Old 06-06-2003, 04:50 PM
shit thanks alot man i was hoping sumone would kno how to figure it out but that reeally helps a lot.......i ber makeing the box pretty soon....thanks again
Old 06-06-2003, 04:58 PM
Honda God
UR Welcome
Old 06-06-2003, 05:09 PM
candlaudio candlaudio is offline
Send a message via Yahoo to candlaudio
well i build sub boxes and i can tell you that if the required space is 1.25 per chamber then if you want some deep bass then make it 1.5 per chamber. i know that isnt alot but you will be amazed at how much of a difference it is. and the reason i know this is me and a friend did a little test, we took 2 8" walmart specials that were 20$ a peice and built a box for them out of 3/4 mdf, each chamber was 1.0 cubic foot, and im gonna tell ya those 2 8's hit harder than i have ever heard an 8 hit before..... but i also built my box ( but later sold ) that has 2 sony xplod 12's in it and each chamber was like 1.5 and it hit like a mutha so if you can build it 1.5 and you will see that it will hit harder and deeper.
