Old 09-05-2012, 06:52 PM
brockw brockw is offline
Blazer wont scan
Can anyone tell me why me 98 blazer will not linkup to my scan tool
Old 09-05-2012, 06:56 PM
old_master's Avatar
Advisor/Moderator
Re: Blazer wont scan
Turn the ignition switch to the RUN position, don't start the engine: Without removing the fuses, check both terminals of all fuses in both fuse panels with a volt meter or test light. Post your results.
You have to know how it works,
to figure out why it doesn't.
Old 09-05-2012, 07:13 PM
Sorry shod have more specific i'm not getting 12 volts to my terminal
Old 09-05-2012, 07:16 PM
old_master's Avatar
Advisor/Moderator
Did you check all of the fuses?
yes
Old 09-05-2012, 07:40 PM
carrfixr's Avatar
carrfixr carrfixr is offline
the cig lighter fuse 15 amp in the instrument panel fuse box feeds the dlc
double ck that one
www.mitchsautoservice.com
Old 09-05-2012, 07:48 PM
carrfixr's Avatar
termnal 16 on the dlc is batt voltage thats the bottom right one orange wire. ck for power at the wire itself behind the connector if fuse is good and report back
Old 09-05-2012, 07:51 PM
old_master's Avatar
Advisor/Moderator
Exactly. In the DLC, the orange wire in pin #16 should show battery voltage at all times. Comes from instrument panel fuse block, 15 amp fuse in position #2.
The Following User Says Thank You to old_master For This Useful Post:
carrfixr (09-05-2012)
Old 09-05-2012, 07:57 PM
carrfixr's Avatar
is there an echo in here..
The Following User Says Thank You to carrfixr For This Useful Post:
brockw (09-05-2012)
Old 09-05-2012, 08:12 PM
old_master's Avatar
Advisor/Moderator
Must be you type faster than I do I use the old one finger hunt & peck method.
brockw (09-05-2012)
Thanks four the help .
Old 09-06-2012, 07:09 PM
just wanted to say that was the problem thanks again
Old 09-06-2012, 07:19 PM
carrfixr's Avatar
thanks for letting us know
