Go Back   Automotive Forums Car Chat > Buick > Century
Old 09-05-2012, 06:14 PM
toughguy5 toughguy5 is offline
2000 Buick century
i just bought a 2000 buick cent. i have two codes that popped up they are, PO410 and P1441. i"ve never owned a car this young before so when you explain to me what i need to do please use laymans terms or pictures will help greatly. thanks.
2000 Buick Century, 71,000 miles. and all else is good.
Old 09-05-2012, 06:40 PM
carrfixr's Avatar
carrfixr carrfixr is offline
Re: 2000 Buick centuary
po 410 is for the air system (air pump)
po 1441 is for the evap system (fuel vapor recovery)
you need specialized equipment to accurately diagnose both things
www.mitchsautoservice.com
Old 09-05-2012, 06:46 PM
nothing i can do myself? replace the part?
Old 09-05-2012, 07:00 PM
carrfixr's Avatar
you can replace the air pump but its would just be a guess. most of the time thats what i find wrong for that code. a reman air pump goes for about 140.00
the evap take a look at the purge valve and attaching hoses
EVAP canister purge valve leaking internally.
EVAP purge and engine vacuum lines switched at the EVAP canister purge valve.
EVAP canister purge valve control circuit grounded.
Old 09-05-2012, 07:02 PM
carrfixr's Avatar
could also be a bad gas cap
Old 09-05-2012, 07:12 PM
thanks for the heads up.
