Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-05-2012, 07:19 AM
Chase3203 Chase3203 is offline
Sounds galore
2002 Ford Mustang Manual V6 3.8L with 60,000 miles
My car is acting a little funky. I hear a sound similar to water running through pipes. It is fairly consistent and seems to change/die down when i press down the clutch. There is also a squeak in idle that seems to disappear once acceleration is initiated. Thinking its in the clutch/transmission area.
I popped the hood to see what the problem could be if it was inside the engine. It appears that the water pump (top left pulley when facing car) is making a little static noise and smells like burning. No leaks thus far, but it could be on it's way out. Seems like the car has lost a little bit of its power as well.
Besides that, it runs like a charm.
Any ideas?
Old 09-05-2012, 08:43 AM
carrfixr's Avatar
carrfixr carrfixr is offline
Re: Sounds galore
facing the car the top left pulley is the a/c compressor. the water pump is in the middle lower down.
www.mitchsautoservice.com
