Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 09-04-2012, 01:20 PM
badtransam86 badtransam86 is offline
2003 dodge neon transmission concern
I was wondering I just got this car the other day it runs and drives great there's no leaks on the car all the fluid levels look good my concern is when I put it in gear it makes a little noise not loud you have to set there and pay attention to it but there's no sign of slipping or anything it shifts perfect in every gear also when you come to a full stop you can hear it is this normal in these transmissions?
Old 09-04-2012, 01:42 PM
carrfixr's Avatar
carrfixr carrfixr is offline
Re: 2003 dodge neon transmission concern
noises from the trans are not normal. maybe its comming from the belt area ?
does it do it in park or drive or both etc
www.mitchsautoservice.com
Old 09-04-2012, 04:40 PM
It's just when you shift it in gear it makes a little sound it don't sound rough just a light sound I didn't know if it suppose to do that or not it makes the sound when you shift it in drive and reverse that's it
Old 09-04-2012, 04:47 PM
carrfixr's Avatar
just a couple guesses maybe worn axles since it does it when shifting into D or R
or engine / trans mounts...
Old 09-27-2012, 06:01 PM
bobgagt1.0 bobgagt1.0 is offline
Tranny bearings maybe?
Old 09-27-2012, 08:52 PM
It sounds electronic but I've been running it about a month with no problems I was thinking shift solenoid maybe the noise it's not something you would notice unless you really listen to it
