Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 09-03-2012, 11:46 PM
Ajillag Ajillag is offline
Burning oil.
My 84 is burning oil. From the side of the engine. Smoke is coming from the engine and the houses that go to my carb air filter. What could this be.
Old 09-04-2012, 02:07 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Burning oil.
Most likely, leaking valve cover gaskets.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 09-04-2012, 10:33 AM
carrfixr's Avatar
carrfixr carrfixr is offline
Re: Burning oil.
agree sounds like valve cover gaskets. when you remove them make sure the oil drain back holes in the heads are clear as this can keep the oil from retuning to the oil pan and causing it to be mre prone to leaking even if you change the gaskets
www.mitchsautoservice.com
