Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 09-02-2012, 10:50 PM
Black Midnight Black Midnight is offline
oil light
I have a 95 plymouth neon and the oil light started coming on when I brake. It has been less then 3 months for an oil change and I do alot of in town driving. I checked the oil level and it appears to be fine. Anybody have this issue before?
Old 09-03-2012, 09:17 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: oil light
Check the oil sending unit and/or the brake switch. They may be dirty/oily causing it to trigger the light.
2003 Dodge SRT-4
Old 09-03-2012, 12:08 PM
Johnobub Johnobub is offline
Re: oil light
How many miles are on the engine?
Old 09-03-2012, 02:32 PM
Re: oil light
bout 98,000
Old 09-03-2012, 02:36 PM
Re: oil light
would taking my car in for an oil change help and would they be able to check that at an oil change? Also how do you know if the part needs to be replaced and how long can I drive it under these conditions? Thanks for any helpful information
Old 09-05-2012, 10:12 PM
Re: oil light
Could be a bad oil pressure switch, couldn't hurt to change oil and filter at the same time.
Try changing oil and oil filter, then replace the oil pressure switch. That would be worth a try to fix the problem.
Old 09-05-2012, 10:13 PM
Re: oil light
http://www.autozone.com/autozone/par...103751_0_8537_
