Old 09-02-2012, 07:49 AM
bombervince's Avatar
bombervince bombervince is offline
Ferrari 360 Modena Spider
This will be a speed build, I only have 3 weeks to the Group Build deadline.
The body is sanded smooth and primed. Nothing much to do before applying the first layer of paint except some cleaning in the rims.
Well done Tamiya, one of the main reason I like to build Tamiya kit OOB is that you will enjoy the whole process without disappointment.
Test fit the head lights... so far OK
sprayed with Gaiya gloss black
1st layer of Ruby Red Pearl
2nd layer of Ruby Red Pearl
3rd layer of Ruby Red Pearl
Old 09-02-2012, 07:50 AM
Re: Ferrari 360 Modena Spider
Heavily "smoked" head lights base
Original rims and custom Pale Gold Rims
I found that the pearl red on black looks pinkish, so I added some metallic red to the pearl mixture and spray another layer
Although the outcome isn't the actual color in my mind but it turn out being a stunning color that I decided to maintain it.
The main technique of spraying pearl coat is a thin 2:8 paint:thinner ratio + 10% of clear. After finish, I felt that I should keep it matt, this so far the best matt color I've ever spray.
Old 09-02-2012, 07:52 AM
Hand-brush the throttle body with red (acrylic)
ok, finally completed the engine compartment, nothing extra, just purely OOB.
Interior done
Latest status,
These are my progress of 4 working nights. Thanks for viewing.
Old 09-02-2012, 09:47 AM
Almost done on this baby, but still have some problems to solve...
the emblems on Ferrari are stick-on type, so I'm trying to convert decals to stickers. First by using H20 overcoat to brush on the decals, creating a bulge.
believe or not, this is the first time I use kit-provided masking tape, it's much more easy compared with doing it your own. I apply some soapy water on the clear parts before sticking the masking tapes on it so that I can still adjust the mask after applying.
Disaster!! extra thin cement flow to clear parts.... what can I do? need help here.
This is the only con on this "almost perfect kit", there's sink holes on four corners of the rear clear parts.
Old 09-02-2012, 09:52 AM
Final teaser pics before completing.. :P
Old 09-03-2012, 04:59 AM
janositamas's Avatar
janositamas janositamas is offline
Good job on the color combo, the rims suit the theme well also. Sorry to see the glue-thing, I bet you can solve it somehow!
Old 09-09-2012, 09:33 AM
janositamas,
thanks, since it's bit hard to recover that I planned to "carbonize" that part.
and here's some small progress
Decals applied on the caliper
the sink holes were sanded smooth with grid 400 sandpaper
result after 800, 1000, 2000, 3000, 6000, 8000
final polishing with Tamiya polishing compound, coarse, fine and finishing
final result.
Old 09-09-2012, 09:40 AM
Making of my signal lights.
first, I heathen a clear sprue and strech to the desire diameter, personally I prefer Tamiya clear sprue as it's more compact and still looks very clear after stretched
then I I heat up the tip, till it becomes rounded, this took some practice, just cut off the sprue if the shape is not nice
cut out, I did extra for my future build
painted the inner with clear orange
end result.
Thanks for viewing.
Old 09-09-2012, 11:11 AM
corvettekid_7684 corvettekid_7684 is offline
Very cool!
Old 09-10-2012, 04:01 AM
euro_z's Avatar
euro_z euro_z is offline
What an amazing colour! Where did you get the red pearl from?
Looks fantastic
Old 09-10-2012, 11:25 AM
nugundam93 nugundam93 is offline
Blarg! Wort Wort Wort!
nice work. shade looks like burgundy red
regarding the cement seeping onto the clear, you could try to polish it out as well. did mine on a GT-R's headlamp cover, worked.
olly olly oxen free
Old 09-10-2012, 11:55 PM
Corvettekid,
Thanks
euro_z
The red pearl is fron Gunze aka Mr Color GX series, a Japanese brand.
nugundam93
A friend of mine said it's called Midnight Garnet, Infiniti & Ford has this color. For the clear part, I planned to "carbonize" it, already spray black now.
Old 09-23-2012, 11:06 AM
Finally completed
Completed Gallery here:
http://www.automotiveforums.com/vbul...03#post7002303
