Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 09-01-2012, 01:05 PM
jjbrop jjbrop is offline
Replace rear wheel beraing assembly 2009 camery
How do you replace the wheel bearing on a 2009 Toyota Camry/ 4 clyinder with ABS? Is it difficult?
Old 11-04-2012, 04:08 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Remove brake rotor.
Unbolt 4 bolts for wheel bearing
Disconnect electrical connector on the inside of the bearing behind the strut.
Hit the hub with a hammer to separate bearing from the spindle assembly.
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
