Go Back   Automotive Forums Car Chat > Cars in General
Old 08-29-2012, 11:15 PM
tannerr52's Avatar
tannerr52 tannerr52 is offline
Talking Bypass the A/C Clutch relay?
Hello all, I just purchased a 1998 Jeep Grand Cherokee Laredo. While I was car shopping, one of my criteria was it had to have A/C, but alas, the great deal I found had no A/C. Oh well its almost winter anyway. Anyway, the A/C system has one of those pressure sensors. The only way to test the car for leaks/ fill the system it to have the clutch engaged, of course. You can do this by unplugging the A/C relay (I know where that's at) and jumping a wire so that the clutch is engaged no matter what and you can fill the system. My problem is that i have NO idea which pins to jump. Hopefully its an easy fix....
Thanks,
Tanner
1990 Pontiac Bonneville- 200k -3.8L SOLD Bye Bonnie I'll miss you.
1998 Jeep Grand Cherokee Laredo- 5.2L V8 - 140k TOTALED You were an ok Jeep...
Current ride:
1996 Jeep Grand Cherokee Laredo- 4.0L L6 - 110k
Old 08-30-2012, 01:24 AM
oldblu65's Avatar
oldblu65 oldblu65 is offline
Re: Bypass the A/C Clutch relay?
You might get a better response if you post it in the appropriate section of the Jeep forum .
" Sometimes I grow so tired "
Old 08-31-2012, 08:31 PM
carrfixr's Avatar
carrfixr carrfixr is offline
it is a 5 blade relay. 3 terminals are the same direction and 2 terminals are the same. you need to connect the 2 terminals togther to power the clutch. it is terminals 30 and 87. another option is to charge it with an a/c recycler which does it with the car off. just to mention that a common jeep leak is the evaporator and to do that the dash needs to come out .big job
Old 09-02-2012, 10:43 AM
tannerr52's Avatar
Ah, ok, sweet. Ill try later today. I sure hope that isn't the case, i would hate to pull out the dash on my new car...:/
Current ride:
Old 09-02-2012, 11:15 AM
carrfixr's Avatar
if no large hissing the best way to ck a leak is to add leak dye then trace it with a uv light you can buy a cheap uv light and glasses at any auto pts store
www.mitchsautoservice.com
Tags
air , clutch , conditioning , relay
