Old 08-28-2012, 07:56 PM
puck2005 puck2005 is offline
2003 a/c vibrations
When I turn on the a/c I feel/hear vibrations from the dash. Almost like a subwoofer - a solid note though. Shut the a/c off, the fans in front of the engine shut off and it sounds fine. Cooling fluid is fine. No noticeable shakes under hood. Any clue? thanks.
Old 08-28-2012, 08:16 PM
Tech II Tech II is offline
Re: 2003 a/c vibrations
Check the compressor and it bracket....check the belt tensioner....
If ok, check the supply and return lines, that they are in their retainers....if ok, if this has a TXV instead of an orifice tube, it could be vibrating or possibly the evaporator is loose in it's bracket....
The key to determining this, is locate the source of the vibration.....try mechanic's stethescope.....
Old 08-29-2012, 08:35 PM
The radiator fans continue to run after the engine is shut off. The vibration comes from that as the ac is shut off by then.
Old 08-30-2012, 10:54 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
If the vibration is there only when the fans are running, you have a blade that is out of balance. Either replace the blade or you can attempt to balance the blade yourself. Would be eaiser to just replaced the blade though.
Old 09-03-2012, 07:49 PM
J-Ri's Avatar
J-Ri J-Ri is offline
How many miles on the car? Has it ever been tuned up? Is the noise/vibration relative to engine speed?
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 09-24-2012, 07:09 PM
I removed the blower motor and ordered a new one. not installed. Today the gauge said hotter than normal engine and started shaking. Car was in heavy traffic. No a/c or heat. Temp went down then car stopped shaking. If there is a fan blade out of balance - any tips on how to replace?? thanks!
