Go Back   Automotive Forums Car Chat > Chevrolet > Cruze
Old 08-27-2012, 08:05 AM
mkvkerala mkvkerala is offline
A/c not cooling at idle
2012 GM CRUZE, is having low a/c cooling at idle,we checked cooling fan condition & found working normally,coolant temp showing normal range,while taking snap short its found low side showing 43-39 psi and high side showing 160-210psi and cooling showing 16 degree, while running the vehicle the temp is showing 8-10degree celesius but while at idle & traffic its showing 16 degree , we have already changed compressor,condensor & expansion valve and flushed the system still the condition is same.
Old 08-27-2012, 08:47 AM
Jeff Collision Jeff Collision is offline
Re: A/c not cooling at idle
A/C in these cars has lower power setting at idle. So you may feel low cooling at idle. It is better to check your a/c pressure level and make sure your thermometer reading is not wrong at all.
Old 08-27-2012, 09:41 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
I would suggest to compare the A/C operation to another IDENTICAL vehicle. You may be trying to fix a normal condition for this vehicle.
Old 08-27-2012, 11:26 AM
when we compared with other vehicle its not same
