Go Back   Automotive Forums Car Chat > Buick > General Discussion
Old 08-26-2012, 06:15 PM
edwinn's Avatar
edwinn edwinn is offline
Buick Enthusiast
Restoring hood pad
I'd like to get some tips on removing and restoring the under-hood insulator pad. There's Buick nomenclature embossed into the black material, however the pad is soiled with road dirt and stained white in places from salt spray. Will assume no replacements are available?
-Ed
Old 08-26-2012, 10:23 PM
danielsatur danielsatur is offline
Re: Restoring hood pad
Under hood heat insulation can be bought at your local Pepboys Auto parts store.
The dorman section should have clips, or plastic pop rivet for easy installation.
Old 08-27-2012, 06:07 AM
edwinn's Avatar
Buick Enthusiast
Thanks for the reply. I had specific questions like "are the stock clips reusable?" and "what's the best way to remove clips w/o damage?" and "can the pad be laid out on the deck and sprayed with the garden hose.. use some mild detergent? or will it det-tre-ate?"
-Ed
Old 08-27-2012, 11:45 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
The under-hood mat is not designed to be cleaned. It would be better to replace the pad, along with new retainers. You might be able to salvage the retainers if you use a trim removal tool set. Click Here for part numbers.
Old 03-11-2013, 04:06 PM
Albertj Albertj is offline
=g
Umm... you *can* clean the hood pad you just can't scrub on it or brush on it because it's fabric will pill.
What works for me is vacuuming the dirt out using a wet-dry vac with brush attachment on the hose end.
Salt you can get out by wetting the salt stain with vinegar in a spray bottle (a windex type bottle) and vacuuming the vinegar back out with that wetdry vac.
Oil you can get off with a spray cleaner like Purple Power sprayed directly on, followed by clear water rinse, then use wetdry vac to get the water back out.
You probably should remove the pad before you do any of this, just pop the retainers off with a trim tool (looks like a screwdriver with a crow's foot).
For fun you can get some fabric paint and go over the embossed "Riviera" in the color (subtle or shocking) of your choice, when the pad is dry, then put it back on. Your GM dealer or local car parts store has replacement retainers (to make up for the ones you bust when doing this).
If your pad has pilled from prior cleanings I have heard that you can recover it with some theatrical curtain yardage (not flammable) stuck on with spray adhesive, but I've never done that.
