Go Back   Automotive Forums Car Chat > Chevrolet > Express | G Van
Old 08-24-2012, 04:02 PM
kgriggs75 kgriggs75 is offline
02 express cargo no start
I installed a new key lock and ignition switch. The old one broke and the electrical switch shorted out. Everything is installed but the van wont start, It will turn over sputter but not run. This is a base model that does not have passlock. I have fuel pressure 66psi and spark but still will not run. Any Ideas? Edit to add that it starts but shuts right back off even if you spray ether in it.
2006 Chevy Uplander ls 3.5 128,000
1997 Buick Lesabre 3.8 and 135,000
1996 Chevrolet K1500 5.7 185,000
plus a 66 belair 65 gmc 70 c10 and a ford
Old 08-25-2012, 09:27 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 02 express cargo no start
Spark to all plugs?
Is dist shaft turning?
Injector pulse?
Add on anti theft or remote start?
MT
Old 08-25-2012, 12:24 PM
Spark to all 6 plugs. Distributor is turning. It has Gps locator, but To my knowlege nothing else. I will check the injector pulse after lunch. 4.3 Cfsi or CPI btw
Old 08-25-2012, 02:10 PM
The security light is blinking but this van according to the rpo codes does not have pass lock. ?????????
Old 08-25-2012, 06:06 PM
MT-2500's Avatar
AF - Advisor
If it starts 2 secods and dye nd security light blinking the anti theft is shutting down injector pulse.
What engine and what van is it?
MT
Old 08-25-2012, 06:18 PM
MT-2500's Avatar
AF - Advisor
I show passlock system on all 3 express vans.
You need to getbengine and anti theft codes for repair.
Post back any codes you have.
MT
The Following User Says Thank You to MT-2500 For This Useful Post:
kgriggs75 (08-25-2012)
Old 08-25-2012, 06:23 PM
It did have Passlock after all, I went through the 30 minute relearn and it fired rite up. I wonder why it did not have the correct rpo code.
Old 08-25-2012, 06:39 PM
MT-2500's Avatar
AF - Advisor
You will have to ask GM about that.
If it does it again better get codes.
MT
