Go Back   Automotive Forums Car Chat > Dodge > General Discussion
Old 08-23-2012, 04:56 PM
shannonblaney shannonblaney is offline
a/c stopped blowing
I was driving down the road when my cold air was was fading from cold to not so cold.. then just warm air. I turned a/c off until I got home. When I started my car and turned the air on it blew air...then I switched the cold air button and my car stalled... Any suggestions.
Dodge stratus coupe 2 door 2004
Old 08-23-2012, 08:53 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: a/c stopped blowing
Does the compressor engage? Is it locked up?
Old 11-16-2012, 08:48 AM
Max144 Max144 is offline
Well i think you are facing some internal problem with your car's A/C. It may be problem with compressor or some other cooling parts. I think you should contact with some expert in your area. He can tell you the exact reason.
[Spam signature file links removed by moderator]
Old 02-07-2013, 04:44 AM
BoyScod's Avatar
BoyScod BoyScod is offline
the most probable cause is the compressor failing you need to check that first.
[Spam signature file link removed by moderator]
