Old 08-23-2012, 03:39 PM
Alpha One Alpha One is offline
95 LeSabre AC problem
The AC in my 95 LeSabre has been working fine, but yesterday it stoped cooling. Today I started the engine, AC on, and in the engine compartment I checked the cold tube going into the passenger compartment. It was cold and condensing water on it, but in the inside it is not cooling. Heat level all the way to the left of course. I don't think there is a filter on this car. Any idea what may be wrong?
Thank you
Old 08-23-2012, 06:59 PM
Tech II Tech II is offline
Re: 95 LeSabre AC problem
Make sure the temp door actuator is working...
Old 08-24-2012, 07:23 PM
imidazol97 imidazol97 is offline
AF -Advisor
Is the air coming out the defrost? On a warm day, that takes all the cool out of the air and the driver won't notice it coming out there. If it is, then check on the firewall for a vacuum tube that is off the connector on the bottom of the vacuum storage box. It often gets bumped when someone reaches in to work on the spark plugs of other things on the back of the engine.
IF air is coming out the dash vents:
Do you have the dual temperature controls? Is the passenger side doing the same with temperature? There are two different electric motors that move the two vents to adjust the temperature blend.
The Following User Says Thank You to imidazol97 For This Useful Post:
HotZ28 (08-26-2012)
