Old 08-23-2012, 06:22 AM
dad061003 dad061003 is offline
1999 Dodge Caravan Engine Stall while going 70 mph
I was riding down the interstate this morning and had my cruise control set at 70mph. all of a sudden the cruise just turn off. I went to hit the gas pedal and there was nothing. No check engine light or anything, no spit, no sputter. I pulled off the side of the interstate and attempted to start the van. the engine turns over fine, but no start. all lights, radio work fine. car has fuel. it did not run hot. Can anyone give me any suggestions?? Thank you.
Old 08-23-2012, 01:52 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 1999 Dodge Caravan Engine Stall while going 70 mph
Sounds like a typical crank sensor or fuel pump failure.
Can you hear the pump turn on for just a second when you turn the key to on/run? If you have the 3.8 ltr engine it should have a fuel test port on the fuel rail. When you press the plunger fuel should spurt out not just dribble. The best way to test pump operation is to connect a fuel pressure gauge to the test port. You should see around 50 psi. Doesn't need to be running as long as you prime it by cycling the key from off to on/run a few times.
Are you getting spark? If not check for voltage output at the coil connector. If it's not there you most likely have a bad crank sensor though it could be a bad PCM, ASD relay or wiring. Crank sensors will often fail without generating a code.
EDIT
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
