Trouble Starting 2000 Altima
2000 Altima GXE 2.4l manual tran
Within the last few months occasionally my altima won't start. When I turn the key the display lights dim and there are no engine noises. It happens randomly once or twice every few weeks. Usually if it doesn't start, I wait a while, try again, mess with lights, switches etc. If it still won't start, it always jumps successfully. Once, it died while I was driving it, sitting at a red light. After about five minutes fooling around with trying to start it, it started again. I had the battery tested, it is ok, not perfect. I cleaned the battery terminals up and it didn't have issues for about a month, then wouldn't start the other day. About the same time that this all started (can't remember how well the two things line up) I got a non-transponder key made for the doors. I tried to start the car with it, to see what would happen. The engine turned over and then died. Also around the same time, my service engine soon light came on, but I figured it was just emissions. Any ideas? |
Re: Trouble Starting 2000 Altima
If the battery is >4years, buy a new battery 1st.
I have seen some transient BCM problems -> P0420 '' Low catalyst '' H20 heated oxygen sensors not doing there job, because of a marginal battery. |
Car died randomly, and having troubles starting, even jumping. I got a new battery for free from walmart. Mine was just over two years old, so still under free replacement. So far so good, but in the past, issues have occurred pretty randomly, so we'll see.
| The Following User Says Thank You to spulsfort For This Useful Post: | ||
danielsatur (08-27-2012)
I have a 1996 nissan altima the car will run but it will not excelarate it will try to cut off miss fire. New plugs wires cap an rotor airfilter all new what do it sound like do anyone know what my trouble is thank you.
I need help the car will run but no excelaraion new cap rotor plugs wires airfilter the car will try to cut off if I try to excelarate would someone te
ll me my problem thank you.
