Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-21-2012, 10:06 PM
Diegov14 Diegov14 is offline
Electrical problem on 95 eclipse non turbo
I'm having my windshield wipers turn on when I turn the car on and the cooling fan aswell. Some of the relays on the fuse box keep on clickIng and I'm not getting power to my engine wiring harness. The car won't crank at all . The alternator shorted out but I replaced the fuse .my headlights don't turn on nor do my signal lights...need help
Old 08-22-2012, 07:53 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Electrical problem on 95 eclipse non turbo
Sounds like you have a lot of stuff going on here. I would start out with the basics, clean the battery terminals and all the grounds, make sure the battery actually has a charge on it.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 08-23-2012, 11:32 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
I would check all the wire looms both inside and in the engine bay for melting or anything open and torn apart. A loom can melt, exposing the wires and then melting those together or to other metal parts.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
