Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 08-19-2012, 11:38 AM
TheRamGuy TheRamGuy is offline
Question 1986 ram RWD to AWD conversion
I'm looking to convert my 1986 Dodge Ram D150 from RWD to AWD, but I don't have the automotive experience quite yet. If anyone could give pointers or know where I could get advice, I would be grateful. Also were I could find parts to do the conversion would be much appreciated, because my search has been coming up short. Thanks.
Old 08-19-2012, 04:45 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 1986 ram RWD to AWD conversion
Hope your drill bits are sharp and you have good welding skills.
The best trick is to call the wrecking yards for a wrecked 1986 4wd 150 to get all the parts for a change over.
Another possibility is a rust bucket 1986 4wd 150 on ebay.
Changing the front suspension from A-Frame to leaf spring will be a challenge including the steering.
If you're wanting real AWD and have very deep pocket$$$, you can look for the running gear from a wrecked Jeep Grand Cherokee SRT8 for sale.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Tags
1986 , awd , d150 , rwd
