Old 08-19-2012, 11:20 AM
rx7king's Avatar
rx7king rx7king is offline
Help, paint pulling w masking tape
Hey everyone,
looking for advice on getting paint to stick properly so it doesnt peel up w masking tape. I wash the parts w warm water and mild soap, prime w tamiya white fine surface primer, and in this instance airbrush w tamiya acrylics. In some cases the tape will pull primer up and everything. The black you see in pic is Zero paints. Does anyone know what I may be doing wrong? Here is a picture of my problem that is ongoing:
Old 08-19-2012, 06:06 PM
RonCla's Avatar
RonCla RonCla is offline
Re: Help, paint pulling w masking tape
I would warm the masking tape with a hair dryer when your removing it as it softens the grip of the adhesive and makes it less likely to pull the paint off.
The Following 2 Users Say Thank You to RonCla For This Useful Post:
jayll (08-19-2012), rx7king (08-20-2012)
Old 08-20-2012, 12:22 AM
rx7king's Avatar
That is a great idea , thanks for the tip!
Old 08-20-2012, 01:28 AM
RonCla's Avatar
If your not already doing so, it also pays to sand the surface of the plastic before any primer goes down.
I usually use around #800 grit to take the shine off the plastic so the primer has something to grip to
Old 08-21-2012, 05:42 AM
stevenoble's Avatar
Try doing it the other way around and spray the Tamiya acrylic paint over the top of the Zero black. The Zero paint is much stronger than Tamiya acrylic and will not stick very well to it and may even melt it in some cases..
Steve Noble
Old 08-22-2012, 04:55 PM
CFarias's Avatar
CFarias CFarias is offline
Try using a lower tack tape. I've had good success with 3M's blue painters tape which can be found at a local hardware store.
The Following User Says Thank You to CFarias For This Useful Post:
rx7king (08-27-2012)
Old 08-23-2012, 07:50 AM
lemansnut lemansnut is offline
What kind of soap are you using? Maybe it's leaving a residue behind. Are you letting them air dry after washing or wiping them off, could it be hard water deposit?
Mike
Old 08-27-2012, 04:12 PM
ianc911 ianc911 is offline
Sand the plastic first before priming to give it some 'tooth'. Wait at least a week after painting before masking to give the paint time to cure. Stick the tape to your jeans and pull off 4 or 5 times to cut the tack before masking with it. Don't leave the tape on any longer than necessary. HTH,
ianc
The Following User Says Thank You to ianc911 For This Useful Post:
Old 08-27-2012, 07:15 PM
rx7king's Avatar
Great advice, I always just went by the thought process to put the dark over the light to make sure color stays the way it is meant.
As far as the type of soap I use, usually just whatever is by the sink and not a lot (hand soap sometimes) though I may still leave residue.
Thanks everyone for a lot of great tips really should help.
Old 08-27-2012, 07:54 PM
RonCla's Avatar
I would never use hand soap to clean your kit as its usually derived from vegetable/ animal oils and fats and could well leave a residue on the surface.
It would be best to wash the kit with a dish washing detergent which are formulated to remove grease and oils.
Old 08-27-2012, 08:06 PM
cjsbosox's Avatar
cjsbosox cjsbosox is offline
AGREED!!!
Also use it on hands before handling kit also
Another day on the job!
Old 09-02-2012, 03:58 PM
nugundam93 nugundam93 is offline
Blarg! Wort Wort Wort!
i think i'm going tangent already but what about using toothpaste to clean up the surfaces before priming?
olly olly oxen free
Old 10-20-2012, 10:58 AM
Zak9000 Zak9000 is offline
Send a message via AIM to Zak9000 Send a message via Yahoo to Zak9000 Send a message via Skype™ to Zak9000
Hi :I had the same problem, what I use is the Tamiya tape, is not to aggressive as other tapes and the most important , is not to leave the tape a long time there, always take it off as soon as possible, I hope this will help.
Old 10-20-2012, 12:35 PM
racer93's Avatar
racer93 racer93 is offline
+1.
This goes doubly true for resin.
Old 10-20-2012, 12:36 PM
racer93's Avatar
I've started washing my bodies with Castrol Super Clean (unpainted, of course) to get rid of mold release agent. It works like a charm!
