Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '83 - '90
Old 08-19-2012, 07:38 AM
murph1852 murph1852 is offline
90 Jetta - won't start, sometimes
All- I am new here so please bear with me! We recently purchased a '90 Jetta for my son. It is automatic, 2 dr, 1.8 engine. No mods or anything. A couple days after we bought it, it wouldn't start (did not do anything, no starter click, nothing). Jumped it and all was good, sure seemed like a battery issue at that point. Since then the same thing happens, although it seems like all is well for 2 days then it will not start. Battery is fine the whole time (we had that tested, plus everything electrical - lights, radio,etc - work fine), but starter will not even engage. Last week it happened again. I tapped on the ignition coil with a hammer and it fired right up. So, replaced the coil. After 2 days (last night) it did not start again. Any advice would be appreciated!
Old 01-19-2013, 07:06 PM
denisond3 denisond3 is offline
Re: 90 Jetta - won't start, sometimes
I have a 90 Jetta with the same kind of condition. It was running okay, then I let it sit over a summer. Next fall I wouldnt crank over. If I connected a wire from the solenoid on the starter motor to the positive terminal of the battery and had the ignition turned on - I could get the car to crank over and start up.
It sat for another summer, and the next year it wouldnt start - because the fuel pumps werent running. They should come on for the first 1.5 seconds after you turn the ignition key to the 'run' position. There are two of them, and I think both of them need to work for proper operation. One is in the fuel tank, the other one is under the passenger side back seat bottom - visible from underneath.
I think mine now has some reluctant relays on the panel above the driver's left foot, but I havent had time to follow the wires and check for voltage in the right places.
If you dont have the Bentley manual you should get it; I
see them on ebay, and I think the manual is still in print. I have never seen factory manuals for the Jettas anywhere. The Haynes and Chilton's manuals are less specific than the Bentley manual, and even the Bentley manual takes a lot of study to try and understand what the electronics and the relays are doing.
There should be a fitting on the end of the fuel rail, on the driver's side of the engine. If you remove its screw you can turn on the ignition and fuel should squirt out. (So only do it where they is no open flame). Also dont drop that little bolt, its not an easy size to find; being metric and tiny.
Good luck, and if you have success, I would like to hear about it.
And getting to the starter to remove it on the Jettas with the automatic transmission is a bear of a job! I removed mine to see if it was the problem, and it wasnt. Took an entire day, and in mild weather at that.
