have had seal replaced twice what would cause seal to keep poping out.
thanx Bruce |
Re: 2002 cav. 2.2 crankshaft seal
Most likely a problem with the crankcase ventilation system allowing pressure to build up in the engine. It could also be extremely excessive blowby (past the piston rings). Does it take some force to get the seal into place? Which engine does it have?
'04 Cavalier coupe M/T 2.2 Ecotec Supercharged 14 PSI boost, charge air cooler, 42# injectors Tuned with HP Tuners Poly engine/trans/control arm bushings Self built and self programmed progressive methanol injection system |
which crankshaft seal the front or rear?? on your 2.2 4cyl
