Go Back   Automotive Forums Car Chat > Pontiac > G6
Old 08-18-2012, 02:25 PM
copierfixerguy copierfixerguy is offline
No Reverse lights on my G6
I have a 2007 G6, base model with 3.5 engine. with 110K.
The reverse lights do not come on in reverse.
They do turn on when it is dark and I unlock the car with the keyless remote.
I have replaced the neutral safety switch (used from junkyard)
I have tried new relay 33 (fuse panel in trunk)
I have swapped mini fuse 17 ( reverse lights) with fuse 5 (emissions) fuse panel in trunk
I have cleaned BCM connectors with contact cleaner and coated with dialectic grease.
Some posts are mentioning the BCM.
I did see a post on a G6 forum that showed everything that the BCM controls and it did not mention the reverse lights.
If it is the BCM. . . I know that I could replace it myself. But what needs to be reprogrammed after I replace it.
Any ideas?
Thanks in advance
