Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 08-17-2012, 11:33 AM
somick's Avatar
somick somick is offline
2AZ-FE head gasket repair
I bet this guy will get thousands of views:
http://www.youtube.com/watch?v=l_RQ0NIif4g
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
The Following User Says Thank You to somick For This Useful Post:
Brian R. (08-20-2012)
Old 09-04-2012, 05:40 PM
JOET/CAMRY JOET/CAMRY is offline
Thumbs up Re: 2AZ-FE head gasket repair
Sam
Thank You for posting the link to this 2006 Toyota Camry 2az-fe repair. I have a 2003 Camry with the same engine and hope that I can avoid doing this repair. They just dont make them like they used to.
JOET/CAMRY
2003 Toyota Camry LE. 2AZ-FE (4 cyl.) engine. 60,000 miles as of 1/07/2013.
Old 09-05-2012, 12:23 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
I wonder if owners can avoid this problem by doing some preventive maintenance.... like keeping the coolant level up or something simple.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 11-04-2012, 04:05 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
What repair is this. Link doesn't work.
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 11-04-2012, 04:53 PM
Mike Gerber Mike Gerber is offline
AF -Advisor
This link is for repairing the threads in the block for the head bolts that are being pulled right out on some of the earlier 2AZ 4 cylinder engines. It envolves using helicoil inserts.
I just tried the link and it worked for me. If you are interested you may want to try the link again.
Mike
Old 11-13-2012, 09:30 PM
VDUBMAN
I see this on about 75% of the 4cyl Camry engines. The threads of the block come with it.
Also happens on honda/Acura 3.2 v6 engines as well as caddy Northstar engines.
I don't recommend the inserts myself but it is proven to work if done properly.
Old 11-14-2012, 01:20 PM
Brian R.'s Avatar
Resident Chemist
What is your recommendation for a fix?
Old 11-15-2012, 09:59 PM
VDUBMAN
Used engine or new short block
Old 11-16-2012, 09:20 AM
Brian R.'s Avatar
Resident Chemist
The above fix is meant for home mechanics, more so than would be an engine replacement or rebuild. I think you're right on what is the best fix.
Old 11-16-2012, 06:45 PM
I'm not sure if a used engine would be the best solution as the block headbolt threads could let go shortly after engine replacement. I have read a post on a different fourm to someone who had this happen to them shortly after they installed a used replacement engine.
As far as a new block goes I suppose that would be worth it if the new block addressed the previous design flaw with the block headbolt threads.
joet/camry
Tags
camry , gasket , head , repair
