Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 08-16-2012, 02:12 AM
mishalah's Avatar
mishalah mishalah is offline
oil p. guage maxed out
2005 Sub 1500LT. I had the guage replaced a second time because I assumed it had gone bad again. Wrong! The guage sits at "0" until I start the engine, then pegs all the way over to max.
So...is that a fuse? Is it a bad wire? Or, is my sending unit bad or disconnected....and where is the sending unit?
2004 Yukon XL Denali Luxo-barge for towing. 6.0L AWD grandpa hauler
2005 Suburban 1500LT/awd/tow/everything else...soccermom cruiser
2008 Nissan Versa HB...wife's skateboard
1997 Jaguar XK8 convertible...best road car ever
1966 Mustang GT convertible...fully restored concourse show car
Old 08-16-2012, 09:23 AM
jyount jyount is offline
Re: oil p. guage maxed out
Don't know the theory of operations of that one, but depending on the way it works that could mean that it's wire is grounded, or the sender is bad, not sure where the sender is on that one. The 2005, 6.0, 5.3, or 4.8?
10 hours away from John Deere master certified
also master certified ASE tech. Exp. in both.
Went to school for cars, wound up staying with Deere dealer for a while, so schooling there too. Also couple years exp in GM and some GM training
Gave up wrenching for "Greener Pastures"
Current job: RN
2010 Silverado Z71 5.3L 65xxx
Wife's
2007 Suburban 1500 LTZ 5.3L 102xxx
Old 08-16-2012, 09:31 AM
They should all be the same anyhow, the sensor goes straight down into the front edge of the intake area right below the throttle body. The best first diagnosis would be to remove the sensor and stick an analog gauge in it's hole and see what the oil pressure actually is. The 'idiot gauge" is far from accurate, it is really just a switch....
Current job: RN
Wife's
