Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 08-14-2012, 06:24 PM
kevin23 kevin23 is offline
Heat from A/C vents
2007 Palm Beach, (yeah, I didn't know they made them either) really a Grand Marquee with white leather. Went to grocery store today, A/C worked fine, came out of store and started car, A/C was blowing hot air "as in heater hot air" in all positions.
Came home and got on this fourm, ran the A/C self test and got code :
025 Intermittent fault in blend door calibration
What do I do now ????
As always Thanks for your help, and Thanks to prmars for the self test directions.
Old 08-14-2012, 08:49 PM
Re: Heat from A/C vents
I ran this test, posted by prmars:
Perform a self diagnostic of the EATC and see if it gives you an error code:
With the on and engine running: Press OFF and FLOOR simultaneously, then press AUTOMATIC within 2 seconds. The EATC will begin the self-test. It may take up to 30 seconds. Soon it may display some codes. Write these down. To exit self test press DEF
EATC System self test error code list
024 Fault in blend door calibration during self test
025 Intermittent fault in blend door calibration,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ( I got this code)
030 Self test indicates automatic temperature control sensor shorted
031 Self test indicates automatic temperature control sensor open
040 Self test indicates ambient sensor short
041 Self test indicates ambient sensor open
042 Ambient sensor intermittent short
043 Ambient sensor intermittent open
050 Self test indicates sunload sensor short
052 Sunload sensor intermittent short
115 Intermittent engine coolant temperature signal
125 Intermittent vehicle speed signal...
After running this self test, I came in and checked my computer for what to do next. A couple of guys said that many times the self test would cure the problem.
I went back out and started my car, the A/C was working again. Don't know if this is a permament cure or just temporary, but it works great at the moment.
Old 08-16-2012, 01:25 PM
My self test healing lasted about 20 miles the first time, then 1-3 minutes on subsequent test.
I have an appointment with a private shop to repair. His estimate $250.00 parts and labor.
Codes were 024 and 025
Old 08-22-2012, 04:01 PM
Got car repaired today, "Replaced Temp ACT" $225.00 at private shop.
Still don't know what a Temp ACT is, but I have cold air.
