Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 2nd Gen 00-05
Old 08-14-2012, 01:06 PM
timd timd is offline
Front wheel bearing replacement cost
Does $600 sound too high to have both front wheel bearings replaced on a 2003?
Old 08-15-2012, 08:22 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: Front wheel bearing replacement cost
What is their rate per hour? Most shops charge by the hour and use a software program to calculate costs. For example, if the job shows it takes 2 hours labor and they charge $75/hr...you are looking at $150 in labor fees plus parts. Try and find a shop that will let you purchase your own wheel bearing/hub assembly and let them install it. It is a cheaper alternative to buying "their" parts (which they get from the SAME store you can).
2003 Dodge SRT-4
The Following User Says Thank You to das2123 For This Useful Post:
timd (08-15-2012)
Old 08-15-2012, 03:06 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
From what I can find, labor is 1.6hrs per side (3.2hrs for both) and OEM bearings are around 90.00 each. So figure around 180.00 plus tax and 3.2hrs x labor rate.
The Following 2 Users Say Thank You to gmtech1 For This Useful Post:
Pinky131969 (11-13-2014), timd (08-15-2012)
