Go Back   Automotive Forums Car Chat > Buick > Rendezvous
Old 08-13-2012, 05:03 PM
dmchrist dmchrist is offline
Vous front wiper motor
I just bought a 03 CXL - I previously had an 02 CXL a few yrs back and really liked it. I have been doing a bit of tinkering with it and fixing certain things. Now I have discovered the front wiper motor is slugish and slow. I tested the main power input to make sure it is getting a full 12 volts and it is. So given that I have a wiper motor shipping to me this week. However I have never changed one out in the Vous; does anyone have any experience with this - maybe offer some tips in this task?
Any information would be appreciated.
Thanks
Dave
Old 08-13-2012, 05:33 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Vous front wiper motor
Windshield Wiper System Module Replacement
Removal Procedure
1. Remove the wiper arms.
2. Remove the air inlet grille panel.
3. Remove the underhood electrical center.
4. Remove the cruise control module.
5. Disconnect the wiper motor cover electrical connector.
6. Remove the wiper system drive module bolts.
7. Remove the wiper system drive module from the engine compartment.
Installation Procedure
1. Position the wiper system drive module to the cowl.
2. Install the wiper system drive module bolts.
Tighten
Tighten the bolts to 9 N·m (80 lb in).
3. Connect the wiper motor cover electrical connector.
4. Install the cruise control module and bracket.
5. Install the underhood electrical center.
6. Install the air inlet grille panel.
7. Install the wiper arms.
Hope this helps!
The Following User Says Thank You to gmtech1 For This Useful Post:
dmchrist (08-13-2012)
Old 08-13-2012, 05:49 PM
Wow - very nice, it looks fairly simple and this should be very helpful. I will let you know my results when I complete the project.
Thanks
Dave
**UPDATE**
Everything went very well and only took about an hour. Thanks again for the help. Now on to the Air ride compressor...
