Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 08-12-2012, 07:27 PM
pvisser pvisser is offline
Send a message via MSN to pvisser
Vibration While driving
Hello.
I have a 2007 Saturn Relay LWB, I realize there is a saturn thread, but it's pretty bare, and it's the same as the SV6.
My question is this.
Our van will occasionally have a wierd vibration occur. Usually when I turn slowly left into our driveway, but on occasion it will happen while driving at any speeds and any direction but mostly if I turned slightly left.
Thanks
Paul
Old 08-18-2012, 02:21 PM
GMCustomerService's Avatar
GMCustomerService GMCustomerService is offline
Re: Vibration While driving
Good afternoon Paul,
I noticed that you're from Canada and had wanted to provide information on how to contact GM of Canada should you ever wish for Customer Assistance. Their phone is 800-263-3777 (Hours: M-F 7:30am - 11:30pm, Sat 7:30am - 6:00 EST).
All the best,
Sarah
GM Customer Service
Old 08-18-2012, 02:40 PM
copierfixerguy copierfixerguy is offline
We have had similar problems with our van. It ended up being a worn front rotor. I would check (or replace) the rotors and brake pads. Pads are cheap. rotors not so cheap. But the cruddy build up on the rotor is very noticeable. also check to see if you brake caliper is floating properly.
Old 08-20-2012, 01:33 PM
rkvons's Avatar
rkvons rkvons is offline
Check your outer tie-rod ends for play.
Old 09-03-2012, 08:22 PM
Figured it out.
It was the parking brake.
I cheated though, and applied it partially and drove for about 30 feet, then released it and all is well.
Many thanks
Paul
