Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '97+
Old 08-11-2012, 01:12 PM
LMScib LMScib is offline
2000 Passat won't start
My 2000 Passat has had water leak into the drivers side from the battery and master cylinder area and the car won't start. I have been told the "computer"( I assume probably the ignition control module?) has gotten wet(also a common problem I have been told}After addressing the leak,what do I have to do to get the car started ? I have heard I could "jump the starter" to bypass the security system and get it going to get it to a mechanic. Does anyone know if this is doable,and how do you "jump the starter"? Also ,obviously replace the module and any damaged wiring,but are these parts available after-market or through salvage shops?
