Old 08-11-2012, 12:13 PM
RyanD RyanD is offline
Check Engine Light Help please.
Hi There,
I have an 05 silverado 1500 crew cab z71 and i have a little bit of an issue with my Check Engine Light being on. The problem is when i tried to pull the code from the computer it wouldnt even read that it was plugged in at all. I talked to a buddy of mine and he said that could possibly be the reason its on. What im trying to figure out is what i have to do to remedy the situation so that i can actually be able to pull codes in the future. My truck inspection is out and need this light fixed Asap any help would be greatly appreciated.
Also every once in a while my battery light comes on and it says i need to service my charging system if anyone could let me know a little more about that it would help me out also because i have never seen it before.
Thank you so much,
RyanD
Old 08-11-2012, 01:24 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Check Engine Light Help please.
If the scanner will not power up, you probably have a blown "cigar" fuse in the underhood fuse box. Check the fuses.
Old 08-11-2012, 06:51 PM
j cAT j cAT is offline
the scanner does get power from the 15amp cigar fuse. this goes to the power ports and to the DLC connector where you plug in the scanner to get the dtc.
the charging issue light may mean a short circuit.
this short could be the alternator diodes going.could also be the voltage regulator/brushes in the alternator as well.
my alternator failed with 100,ooomi on it . and my batteries last 7 yrs then I just change them . so what I am saying is these alternators are weak ! If the alternator is n/g buy a new alternator no rebuild crap.
autozone has lifetime alternator with the lifetime warrantee. new. that is what I got. 3yrs now still good. my regulator corroded .
new alternator has the updated regulator.
Old 08-13-2012, 07:44 PM
GMCustomerService's Avatar
GMCustomerService GMCustomerService is offline
RyanD,
I see that you already have some great insights from members of the community, and it sounds as though you have somebody lined up to get your Silverado ship-shape. If I can help with any GM-related questions (recalls, working with dealership), please don't hesitate to get in touch via private message (include the last 8 of your VIN, current mileage, and contact information).
Sarah, GM Customer Service
