Go Back   Automotive Forums Car Chat > Hyundai > Elantra | Avante
Old 08-11-2012, 10:34 AM
matt5657 matt5657 is offline
Engine Light Never Stays Off
I have a 2003 Hyundia Elantra with 70,000 miles on it. The enigine light came on and it was "determined" by Pep Boys that 2 sensors needed to be replaced-- oxygen sensor bank 1 and ambient temp sensor. A day later the light came back on. It was then determined that they needed to use a different type of sensor that was "intergrated". That was done but the light came back on once again. I took it some where else and it was "determined" a new cat converter was needed. I was assured the light would not come back on after this was replaced. It was replaced and 10 minutes after leaving and paying $700, the engine light is back on again. Anyone know why the engine light keeps coming back on? I'd be willing to bet I never needed the sensors or the cat coverter and it's some malfunction of the engine light and that I'm being scammed.
Old 08-11-2012, 10:50 AM
danielsatur danielsatur is offline
Re: Engine Light Never Stays Off
You need a True Diagnostic Trouble code (DTC)!
Don't leave it to the 3-stooges to analyze your problem, find a retired Mechanic working at AutoZone 1st.
It could be as simple as an old battery, causing bad codes.
If the Catalytic converter was bad, see www.catalyticconverterwarehouse.com
Old 08-12-2012, 07:31 PM
Thanks. The cat converter was replaced and the engine light came on 10 minutes after leaving the shop. I'll be taking it to autozone tomorrow to get a diagnostic code then back to the shop.
Old 09-01-2012, 12:03 PM
Jrs3800 Jrs3800 is offline
I'd like to know what the codes were... as well did they replace the Bank 1 O2 sensor?
