Old 08-09-2012, 01:45 PM
rnelson rnelson is offline
Radiator
Can someone tell me does the 02 buick lesabre have a place to change anti freeze & if so where is it thanks
Old 08-09-2012, 03:19 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Radiator
Should be a drain in the left (drivers) side of the radiator, on the inside (side facing the engine) near the bottom.
The Following User Says Thank You to gmtech1 For This Useful Post:
rnelson (08-10-2012)
Old 08-09-2012, 03:20 PM
imidazol97 imidazol97 is offline
AF -Advisor
Re: Radiator
There's a plastic valve, easily broken I've read, that you can access on the bottom of the radiator. There's a larger diameter hole under it in the plastic air dam. Or you can take the dam off to get better visual access to see what you're doing. Someone said a certain size socket wrench fits onto the plastic prongs on the valve to turn it.
The Following User Says Thank You to imidazol97 For This Useful Post:
