Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 08-07-2012, 10:32 PM
dwi1299x2 dwi1299x2 is offline
Question 97 SOHC Neon Belt squeal
Ok so me and my dad recently replaced my AC compressor+clutch, Dryer, and expansion valve after having problems with the clutch and the AC not working. Now the belt squeals whenever i make turns but it only does this when the AC is on. Does anybody have any ideas on what may be causing this? I am thinking about buying a new steering pump but if there is a cheaper route to fixing this I am all for it. The belt is brand new so it is not the problem.
Old 08-08-2012, 07:43 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: 97 SOHC Neon Belt squeal
You need to tighten the tension for the belt. That is usually why it will squeal.
2003 Dodge SRT-4
Old 08-08-2012, 08:44 AM
Johnobub Johnobub is offline
Sounds like the belt is not tight enough. Tighten the belt. That should resolve the problem.
Old 08-19-2012, 08:35 PM
I tightened the belt and put dressing on it. It still squeals. Any other ideas? Im thinking I'll probably just put on a new pump.
Tags
acbelt , belt , power , squeal , steering
