Idle Speed Suddenly Very Low, 300 RPM
2002 HD 2500 6.0 - Pulled into Wal-Mart, everything was fine. Came out 20 min later, started right up, but felt like it stalled, it was actually still running, (barely). Shut off, restarted, same. Used pedal to bump idle up to normal 500-600 RPM, it was smooth, no misfire or roughness. Drove home, approx 5 miles, and had to keep the idle up at every stop.
Could be IAC? How can I test it/What checks can I do in the darkness, by flashlight? No garage, and no help handy, but I do have tools, and basic test light, dmm, etc. First thought was fuel pressure, but it runs fine going down the road. No lights or codes. Thanks in advance for any advice.
-Jim 2015 Silverado Crew Cab 2500HD 6.6 Duramax 4x4 2002 Silverado Crewcab HD 2500 6.0 4x4 Sold 281K Great Truck 1970 Chevelle SS454 (Gave to my son 9 years ago for his 18th birthday. Yeah, I know, crazy, right? Thank goodness he doesn't drive it the way I would, -er, did...). ![]() 1971 Monte Carlo SS454 Drag Racer. The old girl finally got new paint! 1968 Camaro SS (New race car project). Caged, Tubbed, Back-Half/Ladder Bars. Rolling Chassis (For now). |
Re: Idle Speed Suddenly Very Low, 300 RPM
this will also reveal any fuel regulator issues. fuel filter etc. make a vacuum leak and see if the idle increases to 1100 rpms. then it could be the IAC. the IAC increases air to the engine to increase RPM , but you need fuel. the computer varies the injectors opening but you need the pressure . if the pressure is 50 psi the engine will run but at a low idle. with no check engine light fuel pressure is big ! |
Thanks j_cAT, at least I was thinking along the same lines as you were.
Went out this morning to start up, and just a "click". Volts were good when key was first turned on, approx 12.5, but when turned to Start, the click, then everything went dark. Battery negative cable was a bit loose. (Darn side terminals). Tightened it up, and now all is well. I remembered just before I got to Wally World last night, I had hit the mother of all potholes. (Had not been down that road before, now I know). Roads are rough as hell around here, thinking that must have done it. Would not have figured that would cause my low idle RPM issue though, so I will keep an eye on things. Thanks again, -Jim.
