Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 08-06-2012, 12:59 PM
truc0011 truc0011 is offline
2003 Montana - Airbag light on and no seat belt light
Hi all,
I have a 2003 Montana which has the airbag light illuminated. Also no matter if the seat belt is locked in or not - no seat belt light ever comes on.
I have tried new pretensioners (driver and pass side) with no luck, any other ideas. I have a code scanner but it doesn't scan airbag codes. Any common issues to look for?
Thanks.
Old 08-06-2012, 01:54 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 2003 Montana - Airbag light on and no seat belt light
Without a code(s), you will just be guessing. There could be a internal problem with the SDM, a inflator module problem or a sensor problem. Really need to have the codes read.
It's also possible the the air bag issue has nothing to do with the seatbelt light.
Old 08-06-2012, 02:24 PM
What scanners will read the airbag code (besides the Tech II)?
Old 05-27-2014, 11:21 AM
Scanner can't communicate with the srs computer. Tried a new computer still nothing....must be in the wiring? Any ideas?
Old 05-27-2014, 08:15 PM
Tech II Tech II is offline
By computer, did you mean SDM? Did you check the power, ground, and serial data lines?
Is the scanner you used, capable of communicating with the SRS system?
