Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 08-05-2012, 12:39 PM
Yakman01 Yakman01 is offline
No power steering
....after changing a leaking pressure feed hose and the pump. Pump was changed as it was squealing pretty bad with correct fluid levels. New parts are from Toyota, with over 200,000 on the originals I might as well stay the manufacturer if they lasted that long!! After the change out, I see no leaks and fluid levels are correct. A "friend" (read loosely) said that when the PS pump goes it usually takes the rack and pinion too. Tell me he is idiot I think he is and give me some pointers!!!
Old 08-05-2012, 10:41 PM
Joe W Joe W is offline
Re: No power steering
More than likely there is air in the system and it needs to be bled. Turning the wheels lock to lock usually is enough to purge the air from the system. If not look for a bleed valve and hook-up a hose to a drain pan, repeating the wheel lock-to-lock while ensuring that the fluid level is still in the reservoir.
Old 08-06-2012, 08:30 AM
I'll do that again.
Old 08-07-2012, 12:27 AM
Could you please elaborate? The lock to lock is obvious but have you located the bleed valve?
Old 08-07-2012, 07:51 PM
No bleed valve that I can see. Ideas???
Old 08-12-2012, 05:08 PM
Here's an update....life gets in the way sometimes so the car sat for 4 days before I could get back to it. I start the car on Friday and I have power steering! Drove the car for a few miles and all is good. Then today a little longer trip no power steering after a 10 mile drive, 20 mintues later it's back. Out again and staying out. WTH?!? No I did not bleed anything, no changes. I plan on bleeding the system later this week.
Old 08-16-2012, 11:26 PM
Have you been able to bleed the system yet as this appears to be an issue relating to air in the lines. This could very well cause an intermittent problem... just out of curiosity... what condition is the P/S belt?
Old 08-17-2012, 05:37 AM
Brand new belt. As for bleeding the system I have checked here and on a Toyota forum. Both, from what I can find, in one form or another, say to turn all the way each side and hold for 3 to 5 seconds with the car running. I have done this with the car on jack stands and on the ground. Seems to happen more as the car warms up. Thinking I need to bleed it more, take more time.
Old 08-17-2012, 11:58 PM
famlycar famlycar is offline
my corolla has been squealing for over a month now so turning the steerings left and right didn't help. I may have to drain all the fluid and add some better brand or something. I wonder if transmission fluid would work in there?
