I have an issue with my 2005 Lesabre.
When I go around right hand corner and it is up hill(doesn't always have to be up hill), I tend to get a clunk noise. I have had it checked three times by a shop that I trust, they finally were able to hear the noise last time, however can not find it. Any ideas?????? ![]() Help!!!
2005 Buick Le Sabre: Cooper CS4s, Fram Air Hog and Silverstar Ultras Low beams and highbeams. LED tails and marker lights ![]() , brake/turn signals (front turns too) coming soon, just need to install resistors in circuit.(Sold ) 1999 Intrigue: Fram Air Hog, Bridgestone Potenza G009(Love em, just a little road noise)Upgraded to G019 grids they were even better. Silverstar Low beams and highbeams. Led brake lights, all marker lights and third brake light.
Re: Snap/Clunk noise in front end
Pretty vague, but subframe bolts loose, anything in the suspension loose or worn, engine trans /mounts loose or worn.
Try turning the wheels from side to side with the car on gravel or grass where it will turn without scrubbing your tires and hold your hand on the strut above the tire while someone turns the steering wheel. You'll feel it even if you can't hear it with the motor running. Mine on the 03 happened early enough they replaced it under the 36,000 mi warranty. |
How much should your engine move when you put it in gear and give it a little gas???(not flooring it)
| The Following User Says Thank You to ND4SP For This Useful Post: | ||
smith880122 (08-06-2012)
You need to check the front end thoroughly. It is because of either bad ball joints or top strut bearings.
