Old 08-04-2012, 10:32 PM
terryo1965 terryo1965 is offline
1996 Silverado - no rear brakes
I have a '96 2WD Silverado that I just replaced the rear brake shoes and wheel cylinders. I bled the rears with no problem, although I thought it was weird that there wasn't much air in the lines, but fluid was flowing good. When I went to test drive it the brake warning light stayed on and the pedal goes about half way to the floor. The front brakes are working but I am getting nothing from the rears. The fluid is topped off. I had an old Jeep that needed the front brakes bled after doing the rear in order to "reset" some sort of safety valve. Do I need to bleed the fronts, or am I missing something else. Thanks in advance!
Terry
Old 08-05-2012, 09:06 AM
j cAT j cAT is offline
Re: 1996 Silverado - no rear brakes
Terry
when this work is done the line to the rear wheel cylinder must be kept plugged up if you allow fluid to drain out air will get into the ABS valve body and cause this. also only work one side at a time.
with a helper and the fluid reservoir at full cap on. pump up the brakes until the pedal is high and hard. then bleed off SLOWLY the right rear cylinder. bleed after 4X times also do not bleed to the point where the pedal is to the floor. then shift to the other side. repeat.
never allow fluid to drop too low. if you do then the master cylinder will require bleeding. also you may need to have the system bleed with special equipment to bleed the ABS .
with what you did bleeding the fronts should be done . also GM does not have a fluid replacement interval . GM is creating lots of brake problems and accidents with this policy. brake fluid does not last forever. most quality vehicles this fluid is replaced after a few years . with this done properly and new drums and fresh fluid you will have great braking power/control.
Old 08-06-2012, 09:41 AM
Thanks for the information j cat. I will try bleeding them again and include the front.
