U1255 dtc
1999 Oldsmobile Intrigue 3.8L 253,000 estimated miles.
This afternoon my car just died on me. I was on my home from work on the highway. Since traffic thinned out, I set it to cruise on 70mph. This occured near the exit to my house. I noticed the car bucked and looked at the instrument panel. The oil pressure light popped on and realized the engine shut off. Pulled to the shoulder and plugged in my scanner. My scanner picked up U1255 which is a communication error from module to module. No other code accompanied it. I looked under the hood for any visible signs that caused this problem, nothing. Got back in the car and the engine cranked. However I didn't make it that far as the car reacted the same way. This happened over and over and each time I hooked the scanner up, the same code was still there and no other trouble codes popped up. One of the features on my scannner has reported fixes on certain codes. The top reported fix was "replaced BCM" while a uncommon fix was "replace ignition switch". My last attempt at cranking, I was able to drive the car to the exit and into the local gas station. But only this time I drove it at a slower speed while the previous attempts I had to gun it to get back on the highway. Maybe there is a connection there with the increase of speed but not totally sure. If anyone has dealt with this problem I would love to know how you dealt with it and what parts are in association with the BCM, also what do I need look for cause this is one of those codes that has alot of possible culprits behind it. |
Re: U1255 dtc
http://www.cadillacforums.com/forums...m/t-38170.html
IPC U1255 code? Quote:
-better diagnostic info =Tech2 may find this and maybe it cannot. Try to see if you can find the problem yourself and then maybe try a Tech2. |
Re: U1255 dtc
Went to the gas station to get the car home. I waited till after midnight when there would be little to no vehicles on the road cause the road to my house has three large hills and didn't want the car to die on the way up the hill. The ride home was smooth. The car didn't die, no symptoms. Earlier as I got it to the exit, I drove it at a slower speed thinking it may have something to do with it. With that idea, about halfway to the house, I hit the accelator, driving it 70 mph and no issue (no cops thank God). The car did fine. Maybe it was a fluke but I don't like the uncertainty of taking the highway to work and it does it again. I looked under the dash for any broken wires and loose connections but didn't see any, my scanner isn't seeing any codes. Wish my scanner would show which module wasn't communicating. |
