Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 08-02-2012, 06:01 PM
kenc195 kenc195 is offline
whinning AC at idle
Hi all, any suggestions would be much appreciated. I own a 97 honda Passport (270,000 miles). My air con functions okay, the problem is the noise. At idle+air on, the revs drop and an unusually loud whine can be heard. Increase the RPM and it goes away. Friend says it the AC clutch, may not be getting full 12V signal. How to verify, test or learn more would help a lot
Life is good with my 97 Passport
Old 08-22-2012, 03:49 PM
Re: whinning AC at idle
Thanks for all the help folks, oh wait, nobody responded. The answer to the question was less than 12 volts to the AC clutch coil. New clutch and a relay running direct to the coil resoved it ($325.00). Hope this helps somebody
Old 04-14-2014, 02:53 PM
cherry97rodeo2WD cherry97rodeo2WD is offline
Thanks for posting the outcome results of your problem here, as I have found it most informative and interesting as have similar sounding noise on my vehicle.
