Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 08-01-2012, 08:15 PM
Zoltan137 Zoltan137 is offline
Can't Shift from Park (Will start)
ok, 93 olds will not shift from park with brake pressed. I do not hear the lock disengaging when I depress the brakes.
I have checked every fuse I could find.
I do have brake lights.
I can start the car and it runs smooth.
I have verified that the brake switch and neutral safety switch are working.
Any and all suggestions would be appreciated.
'96 Escort Wagon
'93 Olds Delta 88
'02 Harley Dyna Low Rider
Old 08-02-2012, 10:16 AM
maxwedge maxwedge is offline
A990 racer
Re: Can't Shift from Park (Will start)
Checked the shift interlock solenoid?
Old 08-02-2012, 06:40 PM
I dunno how to get to it.
'96 Escort Wagon
'93 Olds Delta 88
Old 08-09-2012, 02:15 PM
Update:
Sadly...I found the shift interlock about 5 minutes after I got so frustrated that I just yanked on the shifter til it moved...
I got the interlock unplugged and removed it for now, and I have to deal with my shifter being "loose" in a way. I can shift from park but it clicks a few times while not moving the cable at all, then it engages. I can find reverse about where drive used to be, and OD is now all the way down where 1st was.
My new question is, can I replace the shifter and all the parts inside the steering column? Or will I need to find a whole new column to put on it?
I feel so dumb for doing it too...
'96 Escort Wagon
'93 Olds Delta 88
Old 08-09-2012, 06:48 PM
A990 racer
Anything can be fixed, but pulling apart the column can be complicated, a used column requires the key remember.
