Old 07-31-2012, 12:43 PM
Nobby Nobby is offline
AC evaporator freezing
Usually happens after 20mins. I can hear the blower fighting the blockage. I then switch to eco mode and wait till the fan begins to blow again by melting the ice.
The garage did top off the freon to the max and installed a new cabin filter then blew out the condensing coils.
Could the freezing be caused by just a tad over the limit or something else like a bad relay?
Old 07-31-2012, 02:51 PM
brcidd's Avatar
brcidd brcidd is offline
Re: AC evaporator freezing
Your system is designed to NOT to cycle- so a relay bad would not cause this---
You have a bad control valve in rear head of compressor- it can be replaced without removing the compressor IFFFFF you can find a shop to do that without replacing the compressor- they will tell you it is not available, they are wrong- most parts house have them--the mechanic is just lazy- and has never tried this-- I am certain, it is the control valve UNLESS you have charged the system WITHOUT pulling a vacuum first.....air in the system does cause freeze-up.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 07-31-2012, 09:38 PM
brcidd's Avatar
buy one online would be easier - from our site sponsor or from any a/c website
'99 GMC Yukon
Old 08-01-2012, 04:03 AM
i googled intrigue a/C control valve to see what it looks like but does not come up with anything
could it be named differently?
Old 08-01-2012, 05:59 AM
brcidd's Avatar
Yes, type in "V5 compressor control valve"- I just did and got numerous hits..
'99 GMC Yukon
Old 08-01-2012, 09:30 AM
Tech II Tech II is offline
Before changing any valves, I would like a set of gages on this vehicle to see high and low pressures....
